![]() | Home > General > Service Help Plese |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Not an expert on Diesels but Iv`e read on here 7 years or 1??k miles are the trigger points.Can the last garage that stamped the book confirm whether the belts have been changed ? Again the costs seem to add up to what previous threads have mentioned. |
There are 2 belts cam belt and HPFP belt at the rear of the engine, both should be replaced at 105000 or 7 years it's upto you weither you get them changed but 3/4 hundred pounds and piece of mind, or pos £7000 plus for replacement engine if the cam belt let go. 2008 G4 RRSport TDV8 current
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 ![]() ![]() ![]() |
TDV6 engines require the cam belt and fuel pump belt replaced at 105k or years, whichever is sooner. I doubt anyone would have paid to change the belts early on your car so it needs doing. There are a few threads on here and the D3 forum detailing people's close shaves with worn belts, even when sticking to the service intervals. Get them done!
cisco1 Member Since: 14 Dec 2012 Location: Yorkshire Posts: 26 ![]() ![]() ![]() |
Thank you all for your help and advise |
dani_armo Member Since: 22 Nov 2012 Location: Sheffield Posts: 23 ![]() ![]() ![]() |
I've just had belts and service done on mine today in Sheffield for £600 at an Indy. Where in Yorkshire are you, I'd highly recommend them - they are doing other work too |
Thanks Dani_armo
Sorry forgot to mention the service which is £300 inclusive
It's a place called sheffield prestige, have a look on their website. It's sort of in central sheffield not far from the bramall lane if you know it. It's worth giving them a call and mentioning what prices you've got and the fact u live up there |
Hi dani_armo
