Home > General > plastic engine covers
scenery
United Kingdom 2008 Range Rover Sport TDV6 SE Orkney Grey
is there an easy way of removing the pins on the plastic covers?
I broke the first one already using a nail bar
I am trying to remove the lower front covers to attach the bottom end of a hose
Steve Range Rover Sport tdv6 2.7
2008
Post #395154 Mon Sep 16 2013 11:41am
Paddi
Do you mean the two piece plastic rivets type things? (sure they have a proper name but can't remember).
I usually just lever out the central part with small screwdriver first and then the outer part is no longer in tension so will easily slip out.
Sorry if that's not quite what you were after. 2008 MY Java Black TDV8 HSE
Post #395156 Mon Sep 16 2013 12:01pm
scenery
Yes,
I didn't notice you could lever out the centres
Thanks Range Rover Sport tdv6 2.7
2008
Post #395162 Mon Sep 16 2013 12:19pm
Paddi
Thumbs Up Checked - they are called plastic rivets. You can obtain replacement for the broken one from Duckworths. 2008 MY Java Black TDV8 HSE
Post #395165 Mon Sep 16 2013 12:49pm
