Home > Technical > Tow bar question?
sheep1903
Tow bar question?
Hi All,
I have a quick question.
I bought a new detatchable land rover tow bar for my RRS, I fitted it on its clicks in place and I can lock and unlock and detach.
When I press down on the silver small pin (off the car), the lock spins 180 Deg and the main locking pin protrudes out far. When it fitted to the car the lock only spins 1/2 way and the main locking pin does not protrude out the back of the chassis. Is this correct?
I thought that the main pin would go right though the chassis, ( that small hole it locks into) mines seems to be 1/3 of the way.
Thanks
The Sheep
Post #395006 Sat Sep 14 2013 3:36pm
Mine does the same thing. I spent a lot of time looking at it trying to get it to go all the way through the chassis hole. Never managed to get it to do more than you describe though. 2012 SDV6 - it's missing a couple of cylinders
Post #395015 Sat Sep 14 2013 4:50pm
sheep1903
Interesting!
Just want to make sure before I hitch On my caravan next weekend.
Thanks
Post #395016 Sat Sep 14 2013 5:03pm
If I was using mine for towing more than I have been (the horse hasn't been out on an outing for ages) then I'd have a multi-height bar fitted for security. 2012 SDV6 - it's missing a couple of cylinders
Post #395020 Sat Sep 14 2013 5:52pm
DavidHirst
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
My detachable tow bar is the same. Going back to Land Rover dealer on Monday to check it for me. Bought for occasional horse box towing so need to be sure.
Post #395021 Sat Sep 14 2013 5:59pm
bazalab
England 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Tow Bar Pin
Hi Sheep
Try pressing the pin back IN against a hard surface!
If I have understood you correctly that is how I have overcome this as per advice from the fitters of my tow hitch.
Hope this helps.
Bazalab Baza G
Post #395035 Sat Sep 14 2013 8:10pm
sheep1903
Hi Bazalab,
I not sure what that would do. I think from the above comments that this seems to be common.
Guess the question is do the pins stick out the chassis or are they suppose to be 1/3 rd of the way?
Thanks
Paul
Post #395039 Sat Sep 14 2013 8:50pm
DavidHirst
Hi Sheep1903, Spoke to a guy from Land Rover. The factory fitted bracket on the car is tapered at the back so gets thicker towards the top. Theres more of the pin going through the locating hole than you think. Also there should be no green band showing on the lock when it is fitted and as mentioned the key should come straight out when locked.
Post #395081 Sun Sep 15 2013 5:07pm
Cupra
i had the Discovery one fitted to mine, far stronger and sturdy than the detachable one
Post #395100 Sun Sep 15 2013 7:37pm
sheep1903
Hi David, thanks for the comment. Looks like its ok then.
Cheers pal!!
Post #395112 Sun Sep 15 2013 8:11pm
Russben
Mine did the same. I took a very fine detail file to the housing on the car and just cleaned up the rough casting marks in the slot the locking 'pin' goes into. The 'pin' now goes a bit further into its slot.
If you try this don't use an agressive file or you could take too much metal off. You could also try polishing the casting with some fine emery cloth.
I'll add a disclaimer that it worked on my car / tow hitch, but you do this at your own discretion. I'm in the shed, I'll be back in the real world in a minute.
Post #396030 Tue Sep 24 2013 4:52pm
