![]() | Home > Maintenance & Modifications > Front Brake Disc Removal - Help |
You've removed the Torx bolt I assume?
Scottydog Member Since: 03 Dec 2011 Location: Dunfermline Posts: 16 ![]() ![]() |
Yeah, disc bolt removed! Will have a look at the bible.
Bigger hammer and hit it harder |
Quick update. Disc stil not coming off so have taken off the whole assembly and going to garage to see if it can be pressed off.
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
I used a fly wheel removal tool. |
Haybale Member Since: 25 Jul 2013 Location: Co Durham Posts: 30 ![]() ![]() ![]() |
Mine was seized on the other week and no end of "persuasion" would shift it. Quick squirt of WD40 and it popped straight off with the next tap. Just remeber to to use brake cleaner on the disk before putting it back on again |
