![]() | Home > Technical > egr fault = loud hissing noise when taking foot off the gas |
There is but it involves using a diagnostic tool. Obvious answer would be have a look and see which one is the most discoloured and black? Unless you are intending to go Switzerland, why not take the opertunity to bin them? |
If you lift the bonnet, then get someone to switch on the ignition you should hear two clicks, one on the left hand side of the engine and one on the right, if you only hear one click, then chances are there is one that isn't working, the one that doesn't click. Thats the easiest way of checking. The lack of power and plenty of black smoke out of the exhaust is also a tell tail sign that one or even two of the egr's are not working. It could also be the egr cooler that is leaking another common problem on the older models. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
AS you have an 05, just blank them. |
c15ebb Member Since: 01 Jul 2013 Location: norfolk Posts: 85 ![]() ![]() ![]() |
I done this... blanked mine...a while ago now... cant remember.. would i of actually removed the vavles when i blanked them? Can remember some sort of pipe work etc i removed... but i get the loud hiss noise aswell... i didnt straight after i removed them... more so when i put de cat pipe on and full exhaust system
sellick Member Since: 26 Jul 2013 Location: Bath Posts: 47 ![]() |
You can remove them completely, or just blank the pipe off to stop them from functioning. Presumably you just fitted 2 blanking plates? |
Can do it a few ways |
howcome i get hissing noise now then.. sounds cool though... garage says isnt the turbo
If your getting a hissing noise then it must be sucking in air somewhere, if you have fitted the blanking plates to butterfly housing then check there that its not leaking had a few leaking from there with a cut o'ring. And did you remove the butterfly valve from the spindle.
Does it sound a bit like a dump valve, but a lot quieter? My car does it, the OP's car does it. After driving a load of other TDV6's, they all do it too, but it is very faint |
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 ![]() ![]() ![]() |
Dose removing the egr not effect the car in any way? D Ledingham |
disco... yeah kinda dump valve noise... its hearable with radio off.. not mega loud like a dump vavle... only does it off throttle really if i gas it to say 3,000 rpm and let off it goes hisssss for like a second |
Removing the EGR on an 05/06MY car does not affect it in any way, shape or form |
