![]() | Home > Technical > L/km |
Is is not in the settings menu, push the end button on the indicator stalk etc etc In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
sheep1903 Member Since: 22 Aug 2013 Location: Aberdeen Posts: 8 ![]() |
I tried that's it just goes through range, mpg, trip. I see no settings menu? |
Have you sorted it out yet ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
If its a face lift car / 3.0tdv6 like mine then you can change the settings in the service menu under 'trip computer', 'units'. This will change your digital read out to kms, but will also change the trip read outs and your total mileage in to kms until you revert back to mph settings. |
It is very very simple.
