![]() | Home > Technical > Soemthung loose under driver seat |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
have you checked the harmonic dampers attached to the rear end, they are weighty and are designed to swing, and have been know to hit things |
Or maybe your car has the front harmonic dampers fitted and the retaining bolts have come loose? Easy to check by looking in the front wheel arch; the harmonic dampers (for which read big square lumps of iron) are bolted to the chassis just inboard of the rear lower part of the wheel arch liner. The two retaining bolts are in the big hollows in the lower face. 2008 MY Java Black TDV8 HSE
Brendan1213 Member Since: 21 Aug 2013 Location: Scotland Posts: 2 ![]() |
The square block has three i think bolts holding it on and its fixed on solid, i stripped the carpet back and played about with the rear passenger air vent for feet, 50% sure theres a bloody coin or somin made its way through it to the collecter under my feet |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
I could lend you my missus |
largestorage Member Since: 28 May 2013 Location: mirfield Posts: 30 ![]() ![]() ![]() |
mine did just this too |
