Home > In Car Electronics > Ipad Mini Install in a 2005 to 2009 RRS
Page 1 of 3 123>
scottypaul
2008 Range Rover Sport TDV8 HST Java Black
Hi All, I have managed to fit a Ipad mini into my RRS, it works like and charm and looks good. Its been running now for 6 weeks, tom tom works fine.
Post #392088 Sun Aug 18 2013 9:16am
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
Re: Ipad Mini Install in a 2005 to 2009 RRS
Unnecessary quote removed
Have you interfaced it to work with the existing system, 4x4 info, dvd etc? Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #392096 Sun Aug 18 2013 10:09am
scottypaul wrote:
If I have enough interest I will produce the kit to install it. its been running now for 6 weeks
If you are planning on selling these kits, then please read the Commercial Posting Rules
Post #392098 Sun Aug 18 2013 10:23am
scottypaul
No I have not interfaced it with the 4X4 system its something I'm looking at with a wifi obd unit, if the data from the 4X4 system is avaliable on that then I will write a app. This Mod will not work with the DVD system But I dont use the DVD so it didnt matter to me, I will look into linking the Ipad to the rear monitors.
Post #392102 Sun Aug 18 2013 10:50am
largestorage
England 2006 Range Rover Sport TDV6 SE Java Black
I think that would be great, I'd want one
Post #392107 Sun Aug 18 2013 1:01pm
sparky8181
Good work, keep us posted Thumbs Up
Post #392108 Sun Aug 18 2013 1:06pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Looks awesome Thumbs Up , I've been thinking of doing something similar but with an Android Tablet however had a couple of issues namely:
1) The power on/off issue where you need access to the power button, otherwise the tablet can run out of power over several days and then it can't be powered on again...
2) Removal of the existing SatNav and therefore the need to pass through of the MOST system to ensure everything works.
Could you give us an insight in how you got around these issues? Would be appreciated Smile
Thanks in advance
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #392148 Mon Aug 19 2013 5:17am
scottypaul
Hi Guyzer73,
The ipad will come on even if its flat, it will only turn off if you turn it off, as for a android tablet the only way I can think of getting round it is to modify the tablet and make a external switch.
My install has the existing SatNav still in place behind the iPad, but if you wanted to remove the SatNav you only have to Bridge the Most system together from the back of the Unit, you can get a most straight joiner.
Paul
Post #392152 Mon Aug 19 2013 7:25am
Guyzer73
Cheers Paul Thumbs Up
I've actually just found a way round the power up issue, at least for Samsung tablets so that when it receives power it should now reboot... and using the Tasker app I can power the Tablet off when it loses the power connection (through an ignition feed) so that should resolve that, once I find somebody to reprogram the file that is.
For anybody interested in this function the link is:
http://forum.xda-developers.com/showthread.php?t=1187631
And if I can find somebody to do the reprogramming I'll get him to do a custom boot animation with a Range Rover logo Very Happy
Regards the MOST pass through I'll have a look on the 'net where I can find this as there's no chance I'll find it locally here in Oman... The reason for not placing it in front of the existing SatNav is I know I'll have an issue with heat so want to look at mounting it in a floating style at the front of the dash similar to the new Merc GLA. And can then use that as extra storage. You can see what I mean below:
Then using a 'deconstructed' dock I can get power and audio out, and extend the micro SD card slot with this:
The big issue is how to mount this all in a 'OEM' style 'shell' so that is looks as stock as possible... If I can't find a solution to this I'll have to install it where the SatNav is and try and vent some of the air conditioned air to the back of the tablet to keep it cool.
Should keep me busy tinkering during my paternity leave in September...
Post #392158 Mon Aug 19 2013 9:02am
scottypaul
I have had no issue with the ipad overheating, for anyone else that needs to know, I have used an Apple airport in my install and modified it to 12v, I used a 12v to 3.3v power supply purchased from ebay for £3. you will need tell the airport not to look for internet in the settings, this way the 3g still works on the ipad and so does the airplay.
Post #392160 Mon Aug 19 2013 9:20am
Guyzer73
OK that's good to know. The problem is I'm in the Middle East with temps in the shade of over 40C in the summer you can imagine the heat build up in the car, if I have to park in the sun...
I've had the tablet in the car before and left it mounted to the car mount on the windscreen and it took up to 45 mins before it would start charging again, and once or twice wouldn't even boot up until it had cooled down due to the temperature of the Tab being too high.
Hence being cautious about doing a fixed install where it can't be cooled... as it would be Censored if it then regularly failed to work...
Post #392162 Mon Aug 19 2013 9:34am
jetbags
Really interested in this install, do you think you will be able to link into the rear monitors for full DVD system ?
Also, does this still allow steering wheel buttons to function as norm when installed... Would be very interested in a full supply/install price if you are able.
Thumbs Up 2005 Rang Rover Supercharged
Loving every minute !
Post #392354 Tue Aug 20 2013 10:13pm
BioBMS
England 2009 Range Rover Sport TDV6 HSE Santorini Black
That install is genius Bow down Bow down
Just need ipad mini Big Cry
Post #392358 Wed Aug 21 2013 5:20am
Blackbeast
Scotland 2006 Range Rover Sport Supercharged HST Java Black
This is great any chance of getting a how to do guide for this and anything that we require as i would love to add this to my RRS.
Post #392800 Sun Aug 25 2013 6:11am
Blackbeast
Post #392801 Sun Aug 25 2013 6:14am
Page 1 of 3 123>
