![]() | Home > Maintenance & Modifications > after changing my bulbs to lead in the headlights got a mess |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
That is the adaptive headlights icon. Do you have adaptive lights fitted? (they move the beam left and right as you steer). If not, then I'm guessing that you might be seeing a canbus error caused by incompatible light fittings. Did you buy Canbus-friendly LED lights? 2012 SDV6 - it's missing a couple of cylinders
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
they were supposed to be canbus friendly 91 BMW 850CSI |
those
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Put your old bulbs back in and if error clears your led's aren't error free as advertised.
Just did it and its all good now. Man I have been ripped off!! 91 BMW 850CSI |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
That's annoying. Where did you get them from? 2014 L405 SDV8 RR Autobiography ![]() 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone ![]() 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
link is in this thread. I got a answer on another forum that sounds like that. Maybe i need to restart the lights. I will put the leds in again tomorrow and see how it goes. Did you let the car go to sleep before removing the headlights? If not this too may trigger the AFS fault,if you didnt do this,let the car go to sleep,then unplug each headlight,plug back in and try again,if fault still shows up you may need to get the cars brain read for a fault description logged. When i had the problem in my previous post,the fault logged was AFS motor issue,helped me realise my HID ballasts were stopping the movement! Also did you move the eyeballs at all?again a plug and unplug might rest them! HTH 91 BMW 850CSI |
I fitted ones that look the same as those in my Sport recently. No errors so far. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I will fit them again and see what happens 91 BMW 850CSI |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
take the bulbs out one by one and turn it round try that |
New bulbs have been mouted and it is all good 91 BMW 850CSI |
robmeister1969 Member Since: 24 May 2008 Location: Surrey Posts: 125 ![]() ![]() ![]() |
Just curious about your 'HID ballasts were stopping the movement' comment. My AFS has not worked on my RRS SC, and I wondered is you had the same problem and managed to resolve it? |
