Home > General > Advice On TDV8 Problems - Dealer Can't/Won't Help |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
Assuming it's fused I really can't see what the difference would be, a wire's a wire (as long as it's the correct gauge). Makes me wonder if these people are actually qualified to work on cars in the first place, or simply blinkered and behaving as they're told to even though they know better. That's why I trust my car to an independent, at least he's got some common sense "Roads ? Where we're going there are no roads." Back to the future. |
Tue Sep 11 2012 4:54pm |
Does anyone have whatpotholes mobile number urgently?
Thu Sep 13 2012 5:55am |
Contact made. Bodsys Brake Bible
Thu Sep 13 2012 7:02am |
whatpothole Member Since: 05 Jun 2012 Location: Middx Posts: 25 |
Hi guys,
Fri Aug 16 2013 12:22pm |
Great write-up!
Fri Aug 16 2013 2:14pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Only picked up on this late on in the game.....
Fri Aug 16 2013 6:20pm |
Rangster Member Since: 22 Nov 2012 Location: Stoke on Trent Posts: 30 |
Ah, at last someone with the same issue when going around roundabouts or corners. Took mine to the dealer last year and they couldn't find anything wrong with it. Eventually they reset the steering angle sensor as they couldn't find anything else wrong. The problem did appear to go away or not be such an issue but I have recently asked my local Kwik Fit to check the wheel alignment again (they have already done this twice before) as I have slight wear to the outside front tyres. Although they claim the wheels are set within tolerance, I asked them to toe out as much as the tolerance will allow to try to reduce the wear. They made a marginal adjustment and since this time the issue on roundabouts has increased, so I have booked it in to the dealer next Tuesday. I will go armed with a print out of your findings so hopefully they will replace the sensor and the issue will go away for good. RRS TDV8 MY2010 Stornoway Grey
Tue Aug 20 2013 4:53pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
If you have uneven wear and the stability control kicks in on roundabouts, then that suggets your suspension alignment is totally out or soemthing is worn such that when laterally loaded it causes the alignment to be totally out. Did Kwik Fit do a full 4 wheel alignment using something like the Pro Align system? Did they set tight tolerance mode? I wouldn't be suprised to find your wheel alignment is wrong and that you have something like an excessively worn suspension arm bush 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Aug 21 2013 12:06am |
Just to update, went to the dealer who couldn't find any error codes and they checked the wheel bearing which was ok as apparantly a worn wheel bearing can cause this issue. Advised dealer that it could be steering angle sensor and they agreed to change.
Tue Sep 10 2013 9:17pm |
Oops, it was obviously wishful thinking when I thought the issue had gone away. DSC light is still illuminating on corners.
Fri Sep 13 2013 2:47pm |
Sorry for late response; Kwik Fit used a Hunter HawkEye 4 wheel alignment system which was set on tight tolerance initially. The problem with the DSC existed then and this is when I experienced slight tyre wear on the outside. I re-visited Kwik Fit who set the tolerance to max toe out permitted within tolerance. The DSC problem does appear to be slightly more noticeable but the tyre wear appears less. RRS TDV8 MY2010 Stornoway Grey Full Exterior Autobiography Factory Upgrade Piano Black Interior Trim inc Steering Wheel Ivory Premium Perforated Leather 22" 5 spoke "Style 7" Diamond Turned Alloys Towing Pack Diesel Tuning Box Privacy Glass Side Steps Best vehicle I've ever driven. Current garage also includes; Mercedes 320 CDI CLS TVR Tuscan S |
Fri Sep 13 2013 3:15pm |
I still think you have a wear issue somewhere. A sensor problem might cause the DSC issue but obviously not the tyre wear.
Sat Sep 14 2013 6:53am |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
What was the fix with the egr valves? I've had mine for a month and it does that squeak on every shutdown. Reading on here, it may be normal but seems not everyone has the same level of noise? Cheers, Steve |
Wed Jul 15 2015 5:22am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Been reading this thread with interest,,,,, especially the whining noise when the engine is turned off,, always wondered what it was. Mine will whine for a few seconds but is only noticeable if you stand right in front of the car when outside or its in the garage,,, not noise at all 2010 RRS, TDV8
Wed Jul 15 2015 6:54am |
