![]() | Home > Faults & Fixes > Fault codes.. TDV8 2007 |
P02A0 Cylinder 2 Balance P2290 Injector Control Pressure to Low P117D Fuel volume regulator control exceeded maximum control limit. Flack ![]() |
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 ![]() ![]() ![]() |
Thanks flack
That code is a result of the one's below it I would think it looks like you have fuel delivery problem has it been serviced recently .. The cylinder is out of balance because you have a problem with fuel in old terms it means your car is not running smooth and its out of balance with other cylinders.. Flack ![]() |
