![]() | Home > Technical > TDV8 throws a hissy fit? |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Hope it isn't this one:
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4453 ![]() ![]() ![]() |
The above bulletin refers to a whistle under load. Usually just before 2000RPM
^^^ Oh great |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
That sounds like an air leak some where in the system. fairy liquid called for |
Firstly, I would have the 2 top turbo hoses off, and check them fully. Wouldn't be the first time someone has missed a split hose |
OK had the top hoses completely off and found no splits. Started her up in off road height and had a good listen under the bonnet and stuck my head in the wheel arches and could only hear 'normal' noises. Revving up to about 2000 with the driver's door open can hear just a very faint whistle. Test driving noise does not sound so loud unless in between buildings or alongside a wall. Perhaps I'm worrying too much and just suffering from TDV8 Simple 1 saga induced paranoia? 2008 MY Java Black TDV8 HSE ![]() |
