Home > Wheels & Tyres > Spare Wheel Cavity Capacity
Lew White
Australia 2013 Range Rover Sport SDV6 HSE Orkney Grey
I note that a lot of members are running 275 / 45 / 20 tyres as opposed to 275 / 40 20 on their RRS's seemingly without any problems or issues.
Has anyone attempted to fit a rim fitted with the larger profile tyre into the spare wheel cavity? My measurements suggest that a 275 / 45 / 20 will not fit. The radius differentiation is 9mm which suggests to me that the wheel / tyre will hit the middle of the protective shield at its' centre point. Unfortunately I do not have a tyre / rim combination to check my theory.
Many thanks.
Post #390584 Thu Aug 01 2013 12:19am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
The largest tyre I have fitted in the spare wheel-well is 285/60R18. It only fits deflated and rubs hard against the fibreglass heatshield (which has since been removed). A 275/45R20 should be around 1.5" less in diameter, so should fit.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #390585 Thu Aug 01 2013 2:18am
Lew White
OK.....many thanks
Post #390867 Sun Aug 04 2013 11:21am
