Home > Technical > Anti roll bar |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 |
Just removed my passenger side front wheel to investigate remaking and other issues. When I grab the anti roll bar should I be able to slide it left and right a few inches or should it be solid? This might explain one of the knocking noises if its showing the bushes need replacing! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Sun Aug 04 2013 10:41am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
No it should be solid in the bushes if you can move it then then the bushes are worn and need replacing.Also check your lower arm bushes if you have a knocking, just drive the car forwards at around 10 to 15 mph and stab your brake pedal if you get a knock its the lower arm bushes worn.
Sun Aug 04 2013 10:46am |
Thanks flack, is it an easy fix for a DIYer? Just sent you a PM about a few other issues, might be worth me getting the whole front end sorted cause its definitely not right! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Sun Aug 04 2013 11:07am |
pm replied to..
Sun Aug 04 2013 11:11am |
