![]() | Home > Technical > Refurbishing air suspension compressor |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
hi does your car have lowering links on it as when mine had them on it had same symptons |
Shaun75750 Member Since: 27 Jun 2012 Location: Staffordshire Posts: 12 ![]() ![]() |
Mine is doing the same but my compressor
sellick Member Since: 26 Jul 2013 Location: Bath Posts: 47 ![]() |
As far as I'm aware it doesn't have lowering links. It doesn't look particularly low. Shaun that's what I'm concerned about! Although when I lower mine it doesn't do the 'fart' of air, it's more of a hiss, so that's what's pointing me in the direction of the compressor. Thought I might as well refurbish it for the sake of £20 anyway.
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
Have you seen this link from Disco_Mikey
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
The refurb kit for £20 I think is a valve only kit. You can also get a replacement piston kit for £50. |
RRS_PAT thanks very much for that! It's the water trap (drier unit) I wanted to replace. I was referring to these threads:
Sorry if i pointed you at the wrong thing. |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
Did you ever resolve this, I am having the same issues. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
The problem is not doing the job its getting the compressor in bits, most of the time the parts you need to remove are rock solid and the threads usually strip out when you do manage to undo them.
Thanks Flack, I've still not managed to get in touch with you to get plugged in for a diagnostic check, I'm either not in the country or my wife needs the car! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
My nuts did not disintegrate! However, they were replaced regardless. I fitted a second hand unit, which was fine for a few days then the light came back on. Replaced with a new unit, and functioning perfectly! Thanks for the help |
highfellzippy Member Since: 06 Dec 2009 Location: yorkshire Posts: 256 ![]() ![]() |
Check your sensors in the 4x4 menu
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
My car has this and all the sensors onbtge 4x4 menu are red what does this mean? All is fine on mine just cant get accesd |
