![]() | Home > General > EPB Electric Parking Brake |
Hi and welcome to the site Allen |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Yes, there is something horrible about the "shunt" you get when just driving off. I might do that once or twice a week if I get caught out in traffic, but generally at traffic lights, for me it is - stop, with foot on brake pull on EPB, knock it into neutral, foot off brake then foot on brake,select drive and press down EPB and drive off
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Is it ok to go stop, with foot on brake pull, knock it into neutral, then select drive and drive off? I wonder if you put it into EPB for any other reason than to just rest your leg? cheers / Luke Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
I always release the EPB then drive off, just the habit I got into from the XF. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
BioBMS Member Since: 14 May 2013 Location: Oulton. Staffs Posts: 16 ![]() ![]() ![]() |
I stop using foot brake apply EPB leave in drive then pull away and let EPB come off automatically. Very smooth and (so far) no problems. |
Absolutely fine to do that if you wish, but when you manually switch off the EPB it releases slowly, and if you drive off with it on, I dare say it does as well,but there is a bit of a clunk and I dare say it drags on the brake disc/drum?? For a few feet which can't be good for wear. I wouldn't say there was a right or wrong way, it's just preference and habit! Cheers Dave MY10 TDV6 SE (debadged ![]() Gone: a comprehensive list of imprezas and a Merc ML AMG |
I'll try that. It was my X5 got me into no release & pull away.
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
Ive never tried mine, is it a good idea to operate it every now and then ? |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
I normally stop, apply handbrake & when ready to set off again just start to accelerate. Occasionally I apply the footbrake & push the EPB to manually knock it off.
