Home > General > Gear box oil and filtering change? |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
rabcnesbit
Fri Jul 26 2013 6:51pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 288 |
The ZF 6HP26 box can suffer lack of shutter lock in the torque converter, common when your oil is over 50k miles.
Fri Jul 26 2013 6:52pm |
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 |
Flack and Steve, many thanks for your suggestions. Will look into it. |
Fri Jul 26 2013 9:05pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Funny that, my Vogue is doing something similar more like a slip in drive but according to Guy Salmon there is nothing wrong. It doesn't like pulling away or accelerating with trailer/caravan on the back. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Jul 26 2013 10:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
I had mine done by an indie for £190 incl. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Jul 26 2013 10:50pm |
That's not a bad price RRSTDV8. Shame you are based in Northamptonshire. When did you do this and did it cure the problem? Thanks |
Sat Jul 27 2013 2:03pm |
I am in the process of sorting out the importation of a Transmission Flush machine, hopefully sometime in August there will be a mobile option within the site sponsors, so correct oils, and other work at the same time if needed. Paul Redding
Sat Jul 27 2013 3:19pm |
Looking forward to this. |
Sat Jul 27 2013 4:02pm |
Had it done earlier this year - just had it done as part of general maintenance as the vehicle had about 60k miles on it at the time. I reckon LR's 10 year interval is too long. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Jul 27 2013 4:17pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I Think I read (I think on the Disco 3 forum) that you can get a "better" metal sump for the auto box, that allows you to change the filter separately. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Jul 27 2013 4:37pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Gents, I ve been told that our gearboxes are a sealed for life and don't touch them. This also includes the supercharger oil. Have I been told porkies by land rover? |
Sat Jul 27 2013 5:01pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
"Sealed for life" is open to interpretation
Sat Jul 27 2013 6:13pm |
I believe that ZF themselves now suggest that the transmission oil should be changed 80-120k km depending use. So if you run at high speed or tow regularly or go off road then you need to consider changing the transmission oil more regularly than the 10 years given by LR in the maintenance schedule. 2012 SDV6 - it's missing a couple of cylinders
Sat Jul 27 2013 9:20pm |
