Home > General > Hi there |
chRRS Member Since: 26 Jul 2013 Location: sheffield Posts: 19 |
*HSE.....damn you auto correct!!! |
Fri Jul 26 2013 12:10pm |
welcome Chris.
Fri Jul 26 2013 1:33pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Subtle differences, mostly function so 2005-2007 is one group and 2007-2010/11 the second. Subtle changes to software and functions and standard spec between the two. That's it 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Jul 26 2013 2:52pm |
Thanks guys. This issue with failing air compressors, I think I have read on here that the replacement is a better more reliable one, is this replacement fitted to the 2009 from the factory or can I be expecting a bill for this in the future? |
Fri Jul 26 2013 6:16pm |
I think from memory the part number from per 2007 was superseded so 2008 on had the "better" unit fitted but it doesn't preclude further future failure. These are temperamental things and will go wrong without warning 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Jul 26 2013 6:32pm |
