Home > Faults & Fixes > Rattle/Knocking at low speeds |
Nevski Member Since: 25 Jul 2013 Location: yorkshire Posts: 4 |
Hi Martin and all members, I own a 2010 Range Rover Sport3.0 TDV6 HSE(face lift)model, 4th Land Rover I have owned last one being a Disco 3 TDV6, However an annoying rattle/knocking has started which appears to be coming from the front suspension when the vehicle is driven at slow speeds over small potholes or rough areas of road surface. The vehicle has never been off road and has less than 30,000 miles.
Thu Jul 25 2013 6:19pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Lower arms anti roll bar bushes or droplinks |
Thu Jul 25 2013 6:23pm |
Cheers Neil, Main dealer looked at it in march, first said there was nothing wrong but that some RRSports could be prone to annoying rattles that you had to live with They did however take a look and low and behold it all went quiet for 3 months. But it has started up again At least now I have an idea when I return to them.
Thu Jul 25 2013 6:38pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 288 |
They may of just shimmed out your ARB bushes, same issue the D3's have.
Thu Jul 25 2013 6:49pm |
Cheers Steve,
Thu Jul 25 2013 7:56pm |
The D3 setup is very similar but not quite the same.
Thu Jul 25 2013 8:42pm |
Hi Bobby,
Fri Jul 26 2013 8:55am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
A knock would suggest the ARB bushes initially. They are effectively wear-and-tear items. 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 26 2013 9:47am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
I had this for 3 years and dealer said it was a "characteristic" and would not fix
Fri Jul 26 2013 9:51am |
I had ARB bushes changed under warranty by my local LR dealer. That was under the Approved Extended warranty. 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 26 2013 10:00am |
You could refer your dealer to LTB00241v7, Front Suspension Knock Improvement.
Fri Jul 26 2013 10:13am |
