Home > Technical > FIRST PROBLEM.....
reid7774
Scotland 2007 Range Rover Sport TDV8 HSE Stornoway Grey
FIRST PROBLEM.....
Hey Guys, I have my first problem with my car, don't feel cheated anymore Whistle , OK then, had sport out for about half hour and all was fine, parked up for maybe 1 hour, went to go out a run and after turning Ignition on system fault special programes not available came up and the Adaptive front Lighting indicator was flashing amber at me, sport would not start, tried a couple times and battery seems to be draining.....Any advice chaps Thumbs Up 2007 V8 HSE RRS STORNAWAY GREY
Post #389108 Wed Jul 17 2013 6:02pm
H16UUP
United Kingdom 2006 Range Rover Sport TDV6 SE Zermatt Silver
Battery? Only last about 3 years or so. 2006 TDV6 SE, Zermatt Silver
Post #389115 Wed Jul 17 2013 7:52pm
reid7774
Cheers, just checked with indicator and reading very low, so on charge at moment, refit tmoro to get me to garage I hope and get it checked, does it have to be Landover battery or as long as its like for like if it is goosed. Also will faults clear when battery refitted.cheers 2007 V8 HSE RRS STORNAWAY GREY
Post #389117 Wed Jul 17 2013 8:04pm
Alternator on its way out probably - not charging the battery.
What voltage do you get across the battery with and without the engine running? Does the votage increase markedly a few seconds after starting the engine? 2012 SDV6 - it's missing a couple of cylinders
Post #389118 Wed Jul 17 2013 8:06pm
Bodsy
Site Sponsor
Was it parked up with you in it fiddling with buttons....?
Doesn't take long for these to go flat esp if Stereo is on or keys in ignition.
See my reply here
http://www.rrsport.co.uk/forum/topic32023.html Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #389174 Thu Jul 18 2013 8:44am
