Home > Technical > Webasto FBH and a generic OBD-II interface |
Currently the technical side of OBD is a bit over my head so afraid can't answer your question directly. I have a IID Tool which can purge air from the FBH, prime it and fire the thing up regardless of the ambient temp. But if all you need is the FBH functionality - not worth the expense.
Mon Jul 15 2013 1:10pm |
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 |
Will give Torque site a read tonight - there's loads of information but not sure how much is applicable.
Mon Jul 15 2013 2:39pm |
If you search the Disco3 website for Elm 327 you'll find a discussion of the same problem you are having with connectivity. Apparently you need a VAG OBD cable - whatever the hell that is.
Mon Jul 15 2013 2:59pm |
Cheers for the added info.
Mon Jul 15 2013 3:41pm |
Ok, I have an answer. It can't be done.
Mon Jul 15 2013 7:25pm |
I've just re-read my last post and I think it needs a better explanation for anyone else who comes across this.
Tue Jul 16 2013 7:33am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Which version of IID Tool firmware are you running for that functionality? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Jul 17 2013 6:56am |
The current beta version 2008 MY Java Black TDV8 HSE |
Wed Jul 17 2013 7:27am |
Is that the one that will become 2.18? Mine is on 2.17.3 (I think) but I haven't used it since I upgraded it. 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 17 2013 1:03pm |
Think the current beta is something like v2.18.09 (can't recall the last digit). The nice man at Gap updated it especially for me so that I can see the live values for the TC and solenoids 1 to 4 in the gearbox.
Wed Jul 17 2013 1:12pm |
Ah, that makes sense. I saw on the website that the FBH features were to be expanded in ver 2.18. I'm looking forward to the next upgrade 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 17 2013 1:42pm |
The update, if it includes all the beta functionality, will be significantly more powerful with the gearbox reset, FBH, more live values and some reflashing. I was sceptical at first but am now a convert.
Wed Jul 17 2013 1:59pm |
