Home > Maintenance & Modifications > bleeding brakes
baxc
bleeding brakes
does anybody have a guide on how to bleed the brakes on a 2006 2.7 hse thanks
Post #388514 Thu Jul 11 2013 6:52pm
Bobby
Could this help...?
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #388573 Fri Jul 12 2013 12:33am
baxc
thanks bobby Thumbs Up
Post #388582 Fri Jul 12 2013 7:25am
Paddi
Has anyone actually tried this method successfully? I'm asking because on most cars there are two problems associated with this method:
Firstly you are pushing the pistons on the master cylinder further down the bore than they usually travel so run the risk of damaging the piston seals on dry/corroded parts of the bore, leading to master cylinder failure.
Secondly, whilst the bleed nipple is loosened, air can enter the system via the thread, meaning you end up with a soft pedal. Some people overcome this by using plumber's PTFE tape on the thread but it does seem a bit dodgy.
Garages typically use a vacuum bleeding tool which avoids the above problems.
Has anyone tried using the Gunson pressure bleeding kit on their Sport with success? 2008 MY Java Black TDV8 HSE
Post #388641 Fri Jul 12 2013 1:00pm
Disco_Mikey
Never had an issue with bleeding the brakes that way Thumbs Up
Post #388801 Sun Jul 14 2013 7:26am
Paddi
^ Thanks DM good to know. I'm going to change the brake fluid soon. 2008 MY Java Black TDV8 HSE
Post #388822 Sun Jul 14 2013 10:20am
