Home > Wheels & Tyres > Suspension Shocks replacement
Paszko
2005 Range Rover Sport TDV6 HSE Siberian Silver
hi I need some help, my car has been experiencing a very bumpy ride which I suspected were the shockers. the dealers confirmed that this was the case, and that the shockers and airbags would need replacing which is costly.
is this correct or can just shocks be purchased as with non air suspension vehicles?
any advice would be greatly appreciated.
Post #388346 Wed Jul 10 2013 7:50pm
Bodsy
Site Sponsor
Try this.....
http://finder.koni.com/pdf/2100-4069-manual.pdf
Pretty straightforward Thumbs Up
you can get LR shocks and fitting kit or the whole airbag including shocks.
If you get the Koni FSD shocks, then you will also need to buy the LR seal fitting kit as well as they're not supplied with them. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #388367 Wed Jul 10 2013 10:05pm
Paszko
Thanks for that, where would you recommend buying the shocks?
Post #388473 Thu Jul 11 2013 6:32pm
Bodsy
Site Sponsor
either LR shocks, OR the Koni FSD shocks have reported to be excellent for the D3 and can be found on ebay from a seller in Leeds I think for about £680
ebay item number eBay Item No. 230380758900 from larkspeed motorport £675
You will need the seal kit from LR as well when you do it. Thumbs Up
LR shocks are about £600 last time I checked (but they're always changing) Bodsys Brake Bible
See it HERE
Post #388490 Thu Jul 11 2013 6:42pm
Paszko
Cheers.
How difficult are they to replace? My old mans lending a hand, he's an engineer with experience on older cars such as mgs.
Lee
Post #388518 Thu Jul 11 2013 6:53pm
Bodsy
Site Sponsor
using the koni instructions, its pretty simply. although some soapy water might help in both getting it apart and putting the new one in.
Just be careful when releasing the air!!!
Id suggest the whole car on axel stands TBH, as it'll sit right down once youve dropped the air out. Bodsys Brake Bible
See it HERE
Post #388552 Thu Jul 11 2013 7:31pm
