Home > General > Tailgate stuck !!!! |
chrisebabes Member Since: 14 Jul 2010 Location: Cornwall Posts: 79 |
My tailgate has decided not to open the glass top bit, if you push the button the whole thing opens but not just the glass bit.
Wed Jul 10 2013 7:07am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Chris - do you mean remote button
Wed Jul 10 2013 7:35am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
forgot about that button mine was always programmed to open entire boot lid 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jul 10 2013 9:10am |
Hi guys. No not the button it's the other one for the glass bit. Button works fine to open the whole thing. |
Wed Jul 10 2013 10:40am |
Prime suspect is the switch - known to be a weakness. You press the rubber cover which operates a lever which in turn operates a tiny microswitch. The whole switch assembly is a simple DIY job to replace; it can be carefully levered out without doing any other dismantling but there is less chance of doing damage if you first remove the plastic trim piece below the rear window glass and gain better access.
Wed Jul 10 2013 10:59am |
Preston-rr Member Since: 10 Sep 2010 Location: Preston Posts: 239 |
Hi, how do you programme the remote button to open the glass as apposed to the whole boot? cheers 2014 RRS HSE, SVR body kit fitted. Black on Black |
Thu Jul 11 2013 11:37am |
According to handbook for 2006
Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW Still hoping for a S2 one day! |
Thu Jul 11 2013 11:50am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Hi Chris yes it is the tailgate switch which is at fault. Remove switch from between number plate lights. Remove rubber cover and you will see the problem, the alloy hinge piece will be corroded. When you push the rubber button, it pushes the hinge up onto the micro switch. But because it is corroded it does not move. Scape it off and give it some WD40. I did this 18 months ago,still working fine. A new switch on ebay is about £25 itisme |
Sun Jul 14 2013 7:26am |
Got a new switch took all of 2 mins to fit now I'm a happy bunny again, thanks for everyones help |
Sun Jul 14 2013 8:34pm |
another victory for the forum. Always good to hear the outcome. 2008 MY Java Black TDV8 HSE
Mon Jul 15 2013 10:05am |
All sorted with this thanks to flack who had the RRS in last week for a service, cambelt changes. Really nice guy, very knowledgable, ran me back to work and sorted my tailgate switch for the upper section which wasn't working. Gives me real piece of mind knowing a local guy that I can trust and has the knowledge of these.
Thu Jul 25 2013 10:23pm |
