![]() | Home > My Range Rover Sport > Alignment question |
fallschirmjager Member Since: 31 Mar 2013 Location: United Arab Emirates Posts: 22 ![]() ![]() ![]() |
If your tyres are toed out then you should have excessive wear on the inside. Have you? Any abnormal wear on tyres should be investigated and put right. |
jagspete Member Since: 13 Jun 2013 Location: Valencia Posts: 165 ![]() ![]() |
thank you
Yep, just get an alignment for peace of mind anyway mate. Can only be good in the long run. |
oh yes sure thanks again tdv6s 2.7 2007
Check your lower front wishbones and your rear uppers and the rear knuckle joints before you take it, if these have play in them then a wheel alignment is a waste of time until these are fixed.
Thanks Flack,
Simple test for the front lower arms is to drive the at about 15 mph and dab your foot on the brake if you here a knocking then the bushes are shot.
Thank you Flack! tdv6s 2.7 2007
Hi Flack, So we did the alignment and I have 2 front lower control arms to change at 55 000 km. We are changing them next Wednesday. tdv6s 2.7 2007 xkr 5 2010 |
