![]() | Home > Wheels & Tyres > Do 19 inch wheels from current RRS fit the new model? |
The 2014/15 "new range rover" wheels and tyres are totally different to the outgoing.
gmilner Member Since: 19 Jul 2011 Location: Perth Posts: 26 ![]() ![]() |
Great thanks for that, I'll quiz the dealers on it when they get here. Greg Milner
As an example:
Yeah Mike, I get that the wheels look different on the new model...but does that necessarily mean the 'old' wheels won't fit on the new model's hubs? You can certainly order 19 inch wheels with the new model, so I would guess LR wouldn't bother going to the expense of changing offsets etc just for the sake of cosmetically different wheels...would they??? Greg Milner
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
If LR see a chance to make money selling new wheels they will definitely not fit |
I wasnt talking about the PCB or whatever its called - ie the layout of the bolts (although that might change they have done it before - D1-D2-D3 F1 -F2 RR etc) I was talking about the clearance for the brake calliper looks different (eg the calliper is bigger)...just because you have a 21" wheel isnt the only factor AND the actual tyre profiles have changed - meaning you wouldnt be using the correct profile...let alone speed rating! Mike 2014 Facelift Discovery |
