![]() | Home > Faults & Fixes > Another 'no sound' problem |
When this happens on boot up one of your ecu's on the most system is not booting up as its a ring and if one does not boot up it stops the others after it from booting up, the only way unless it stops working fully is to put a bypass on each most connection on the module and see if it does not lock up any more.
RCT65to92 Member Since: 10 May 2013 Location: Rutland, England Posts: 10 ![]() ![]() |
Thank you flack. Although I really appreciate the response I confess I don't understand it, especially 'most system' reference. ![]() Edit: Since this post I have been searching everywhere and found the same sort of help with a detailed explanation of the MOST fibre optic bus which has helped me understand flack's response. The same issue comes up on Disco3 and FFRR forums it seems. One of the best references I found is here: http://www.landyzone.co.uk/lz/f10/l322-ent...65773.html Hope this helps anyone else searching for a reason for the dead satnav and radio problem! There certainly seem to be plenty of us ![]() Triumph Bonneville T100 Last edited by RCT65to92 on Wed Jun 26 2013 7:17am. Edited 1 time in total |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
mine did this once, it was a poor battery. The battery worked fine, started the car fine etc, and I really didn't believe the dealer when they said it was the battery. Changed it, and all A1 perfect again ! |
