Home > General > I need Help for my first Land Rover, a 2.7 tdv6s.
Page 2 of 3 <123>
simple1
There isn't a more firm setting. Some earlier cars didn't have active ride but all only have three suspension ride height adjustments. The latest cars have a dynamic suspension setting but not on yours I'm afraid 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #385905 Tue Jun 18 2013 8:09pm
jagspete
2007 Range Rover Sport TDV6 S Buckingham Blue
Thanks a lot. I contacted Pete at Bellautos but no response yet. tdv6s 2.7 2007
xkr 5 2010
Post #385918 Tue Jun 18 2013 10:15pm
jagspete
I have a question, regarding the suspension settings, there is 3 different one, can we use the lowest one for driving?
and i could not see if i was in the middle position or high?
I totally lost with the suspension settings. tdv6s 2.7 2007
xkr 5 2010
Post #386479 Thu Jun 20 2013 6:34pm
You can not drive in Access Mode (the lowest ride height). Above a certain speed the vehicle will automatically raise itself to Normal Mode (the middle ride height). The last setting, Off Road Mode, is also speed limited and the vehicle will lower itself back to Normal Mode at a set speed.
You can adapt the suspension to run at a lower or higher ride height by fitting aftermarket suspension height sensor connecting rods (or by using an electronic system such as the IIDTool to re-calibrate the suspension heights.
Running at lower ride heights obviously gives you restricted bump travel. This means a harder ride and more chance of suspension damage. 2012 SDV6 - it's missing a couple of cylinders
Post #386481 Thu Jun 20 2013 6:53pm
jagspete
RRSTDV8 , yes I know what you meant I set up a lowering module on a xj already, maybe i will not do anything then, even unsure to remaps it,
What is your thought about remaps, it can damaged the turbo faster or nay expensive part?
Thanks! tdv6s 2.7 2007
xkr 5 2010
Post #386488 Thu Jun 20 2013 7:50pm
jagspete
One more question,
I have the lights on, I turn off the car there is a ring, (cause i forgot to turn off the light switch) the light is off, I turn off the light switch to 0, the lights went on. so indeed to turn off the light i need to play with the switch from on to off and then a second time on and off again and then it 's off correctly. I may have a bug there.... tdv6s 2.7 2007
xkr 5 2010
Post #386494 Thu Jun 20 2013 9:11pm
simple1
You can set a delay on the dash for "coming home lights". So if set for 30 secs, when you turn car off, the. Lights stay on for set period. Turning light switch from auto or headlights to sidelights over rides this. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #386521 Fri Jun 21 2013 8:30am
SRE
Spain
jagspete
The ride will be cr Censored p if you lower the ride height. I think you may find that the car drops when nipping along a decent pace.
Post some photos
Post #386538 Fri Jun 21 2013 9:38am
jagspete
yes thank you Simple1,i find out today, its exactly what's happening.
Thank you SRE! tdv6s 2.7 2007
xkr 5 2010
Post #386542 Fri Jun 21 2013 9:45am
jagspete
SRE wrote:
jagspete
Post some photos
I am not going to do anything, no wheel change, no module to lower it, and no remap finally, or later. Do you think a remap could break the turbo prematurely.
one liter of coolant was missing and the battery need 1.5 liter of distilled water...i am this afternoon at land rover as he is a friend of mine. tdv6s 2.7 2007
xkr 5 2010
Post #386543 Fri Jun 21 2013 9:47am
SRE
Spain
I am not going to do anything, no wheel change, no module to lower it, and no remap finally, or later. Do you think a remap could break the turbo prematurely ????
Been there said the same, so clear or better still smoked side repeaters, colour code the outer edge of the grill, plus the door bottoms, side vent outers, front and rear lower bumpers then finally the lower tailgate bit.
Peter Bell remap, this changes the car, makes it like it should be, drives more like the 3litre sport.
Your could be lucky, an 07 maybe a euro 3, so you can blank the EGR valves.
Nearly forgot, new colour coded door handles. Thumbs Up
Post #386578 Fri Jun 21 2013 3:27pm
SRE
Spain
PS.
If euro 3
You can remove the cat, and fit straight our chrome tail trims. Whistle
Post #386581 Fri Jun 21 2013 3:33pm
jagspete
SRE, thanks a lot,
I asked the dealership they said if your engine will last 8 years with a remap it will last 4 years. I know it s_cks like response but i am broke like a pair fo shoes now...
I am tented to do it but i have no warranty and a xkr 5 liter to maintain too.
Thanks a lot guys, re all these modification, it be cool to see some photos... tdv6s 2.7 2007
xkr 5 2010
Post #386592 Fri Jun 21 2013 6:18pm
jagspete
SRE wrote:
PS.
If euro 3
I did not get anything out of your euro 3...thing?
how can i find out¿ sorry if i am being such a... tdv6s 2.7 2007
xkr 5 2010
Post #386607 Fri Jun 21 2013 9:19pm
jagspete
1JBS wrote:
Mine is an S and came with 17" wheels which I changed to 19" and it totally tranformed the ride and drive Thumbs Up
But what engine do you have, mine is a 2.7? does all S serie are 2.7? as i am concerned with bigger wheel it may feel slower. tdv6s 2.7 2007
xkr 5 2010
Post #386616 Sat Jun 22 2013 3:40am
Page 2 of 3 <123>
