Home > Technical > Upper section tailgate won't open
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
I am not sure if the upper section of the tailgate is working correctly? The main tailgate open fine with the round button, but the upper section won't open. Is it set to ow open with some weird locking set up, is there a way to wipe all the locking settings etc so I can open it? If its just broken what is the likely cause? Is there a way to know for sure?
Thanks 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #385613 Sun Jun 16 2013 7:29pm
PEACHY
Try pressing the Landrover oval on the remote - this is factory set to open top tailgate Thumbs Up 16MY Estoril Blue SVR.............
Post #385624 Sun Jun 16 2013 8:04pm
fkarim
Are you trying to open the upper tailgate while the main tailgate is also open? They are mutually exclusive. If not, then you might have a faulty switch or may be a blown fuse (if the the two tailgates use different fuses).
Post #385625 Sun Jun 16 2013 8:10pm
Quite a few posts on here about corroded switches so if you do find its broken, I think I recall seeing here that its a fairly easy fix. Thumbs Up ON THE WAY: BMW F21 M140i
Post #385639 Sun Jun 16 2013 9:09pm
Preston-rr
Thanks guys. Will try the oval button tomorrow. Wasn't trying to open the upper tailgate with the main tailgate open. Maybe it is the oval button? Will try tomorrow.
Cheers 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #385641 Sun Jun 16 2013 9:13pm
Bodsy
Site Sponsor
Likely to be the microswitch, easy enough to change tbh. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #385645 Sun Jun 16 2013 10:10pm
Preston-rr
Tried the oval button but still can't open the upper section of the tailgate. What shall I try next? 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #385759 Mon Jun 17 2013 6:33pm
