![]() | Home > Maintenance & Modifications > Air bag light |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Did you try cancelling the fault ? I had the same problem - it was a canbus error - cancelled it and it hasn't happened since. It's the cheapest & first place to start |
Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95 ![]() ![]() |
Cleared it a few times but straight back on, fault has only happened since it was plugged in for the suspension fault! |
So it's the same diagnostics tool that your using to clear the fault ? |
Yeh! Have even tried disconnecting battery and shorting the connections |
Pm sent |
