Home > Maintenance & Modifications > Sport 2.7tdv6 2007 injector rate
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Hi all not posted for a while (had no problems lol)just been lurking in the background in theory i still ant got a problem just looking for an answer if anyone can help ? Was playing with the diagnostic computer and looked at the injectors rate and noticed they are different numbers? Can anyone tell me wat they should be or point me at where to look ?
These are the readings
cylinder balancing offset injector 1- 1119
Cylinder balancing offset injector 2- 856
Cylinder balancing offset injector 3- 1145
Cylinder balancing offset injector 4- 950
Cylinder balancing offset injector 5- 904
Cylinder Balancing offset injector 6- 1019
Cheers in advance guys !!!
Post #385401 Thu Jun 13 2013 9:02pm
flack
Was this at idle speed as I think it is did you try to increase the rpm to 15,000 or higher and then check the readings...
Flack Thumbs Up
Post #385406 Thu Jun 13 2013 9:23pm
sestorious
Hi yes this was at idle speed ! Should I have revved it up too ?
Post #385419 Fri Jun 14 2013 7:29am
flack
Yes you might get a more accurate and even reading then..
Flack Thumbs Up
Post #385422 Fri Jun 14 2013 7:35am
sestorious
Do you know wat readings I should be looking for ? Wat levels it should be ? Cheers
Post #385482 Fri Jun 14 2013 6:58pm
