![]() | Home > General > ignition live in bonnet ??? |
Sorry Saty,
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
In mine I took the feed from one of the empty relay sockets, you can just plug in with a normal spade connector.
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
Ahh this sounds like a plan, could you possibly take a pic of which one you put a spade into ..? .. already got the in-line fuse and cable wired and ready, just need the ignition power. Cheers |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
pm sent |
Here is the one I used.
Thanks buddy & PM replied.
flydive thanks mate that is perfect, now I know exactly what to do, pictures speak a 1000 words.. Cheers ![]() ![]() |
Found the plug and all working.. Thanks for the assistance everyone |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Just been reading this as im looking to wire up an original set of Range Rover DRL's that I managed to get my hands on last year. I already have some headlight led's wired up, but these are as side lights.
Yes. Always best to use a relay too.
Yes again. Make sure you create good waterproof connections if your tapping into the vehicles wiring. ![]() I would suggest you use a relay to shut the DRLs off with the headlights too. ![]()
Can you post a picture or a link to the relevant lights? Is there an additional feed built into them? ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Isn't the "positon light" the additional light that is part of the Adaptive Headlights that comes on at less than 30MPH when turning and illuminates the kerb/ road edge? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
That's the cornering/static bending lamp. |
Then the other thing it could be is the lamp fitted behind the orange front and rear side refelctor plates that are part of the lamp units for the USA spec cars but not fitted in European Market cars as far as I know. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I assume it means just a standard sidelight but what I'm wondering is, is it a separate light, or does it dim, or is it related to its functioning in relation to the vehicle sidelights? Visiting from DISCO3.CO.UK
[quote="Lost for Words"]
Very late reply but here's the pic. This has been in the garage for 8 months so thought I'd best pull my finger out. One feed is "DRL & position light," one feed is DRL ONLY. Any ideas? ![]() http://www.rrsport.co.uk/forum/topic46383.html |
