![]() | Home > General > DSC light coming on |
did you have a full 4 wheel alignment. Did you get a print out? Hunters systems seem to be the best at showing how these cars should be setup.
Javared Member Since: 05 Jun 2013 Location: Scotland Posts: 2 ![]() ![]() ![]() |
Wheel alignment done on all 4 wheels. Didn't get a print out though! Tyres tread depth and pressures fine. |
Think this came up once before and turned out to be completely unrelated to wheel alignment. Tried looking for the thread but can't find it. From my cloudy memory, I think it was something to do with brake light switch damaged when the steering wheel locator was attached. |
I forgot one other thing, could be your steering wheel sensor.
Check your rear tyres as well as this can cause this fault not just the front end
Monkeyman Member Since: 20 Jan 2014 Location: Plymouth Posts: 6 ![]() ![]() ![]() |
Hi, Can anybody help me with an issue I seem to have created? I have an 06 RR Sport HSE 2.7TDV which I have just fitted new alloys to and now the DSC light flashes and cuts in when taking corners, even at a reasonably slow speed which has never happened before. The car was running on 20" wheels fitted with 295 / 40 tyres which were mixed from front to rear with no problems at all. I needed at least 3 new tyres due to wear so decided to buy a set of used wheels and tyres online. I now have a set of 20" "Style 11 Westminster" wheels fitted with Pirelli P Zero 275 / 40 / ZR20's which came off a 2013 Vogue. As my car has Brembo front brakes, the wheels were supplied with a set of TPI 30mm spacers to avoid the wheels hitting the front callipers. I was recommended to fit spacers to all 4 wheels to ensure correct alignment, which I did but I now have this issue. Has anybody else come across this and does anybody know of a solution please? Any help gratefully received.
