Home > General > Bonnet open error |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Think it's the nearside ( right as you looking towards engine ) that has the switch in it. Make sure you haven't left any tools under the bonnet 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Jun 01 2013 7:32pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
I always have to push down firmly with the palm of my hand in both front corners of the bonnet before it will shut properly, you get a nice reassuring click when its shut down ok otherwise I get the dreaded honk! MY16 AUTOBIOGRAPHY Indus silver with some toys
Sat Jun 01 2013 7:38pm |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 |
Haha defo checked for tools.. I also found the plug on the drivers side bonnet catch, removed the plug and the re plugged it in.
Sat Jun 01 2013 7:39pm |
Hi... After a few attempts I let the bonnet close from a height just in case it was that, seems to be securely shut.... Blasted honks LOL |
Sat Jun 01 2013 7:41pm |
Have a look at this thread: http://rrsport.co.uk/forum/topic20468.html?highlight=hood+switch
Hi Paddi Actually the switch did have lubrication on it when I checked earlier .... I will wipe it & try again (mrs has popped out so will try when she returns) Cheers for the heads up and link |
Sat Jun 01 2013 7:52pm |
another emergency trick is to stick a paperclip into the plug, thus completing the circuit. (obviously tape it up to stop any short circuits) RRS gone
Mon Jun 03 2013 7:37am |
Paper clip has fixed the issue for now.. Must be a dodgy switch, will speak to dan and get a price for a replacement
Mon Jun 03 2013 9:41pm |
Replacement switch arrived, any one changed this before? Is it difficult?
Thu Jun 06 2013 8:14pm |
no, its really easy. You can work out which bits clip where on the one you have as replacement. 10 minutes tops, inclluding opeonong the car/bonnet etc Bodsys Brake Bible
Fri Jun 07 2013 7:40am |
Cheers.. I will give it a go tomorrow |
Fri Jun 07 2013 7:41am |
