![]() | Home > General > Advice wanted-possible purchase of 09 RRS V8 Diesel |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
For me, I'd walk away as the service history is poor, the first being way over due.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Walk away. The service history and the four different tyres scream "unloved". 2012 SDV6 - it's missing a couple of cylinders
Yep. I've only been a TDV8 owner for 12 months so still learning but afraid I agree with previous posters. Oil changes according to service schedule are crucial. The TDV8s clearly have a weakness in the turbos and if they blow take the whole engine with them. We don't know the exact cause yet but it is tempting to speculate it is oil sludge restricting oil flow to the turbo bearings which then overheat carbonising the oil and eventually failing without warning or carbon build up on the variable nozzles causing a condition called 'overboost' or a combination of both. Frequent oil changes using top spec oil and the use of premium fuel may help lessen the chance of such catastrophic failure. 2008 MY Java Black TDV8 HSE
Pipes with oil are coming from and going to inter cooler and do get oily.... Just before the turbo/turbos let go. Mine were oily when I lifted the bonnet after blow up. Have never been oily before. |
SunnyR Member Since: 27 May 2013 Location: Beaconsfield Posts: 2 ![]() |
Thank you all for your replies.
Buy the best you can afford and preferably from a LR dealer. Get one with Approved Warranty if at all possible.
In this particular case, I think you have made the right call |
customcarsuk Member Since: 15 Mar 2013 Location: west midlands Posts: 76 ![]() ![]() |
You would have saved more than that in the long run. You did the right thing mate, Rather be safe than sorry. For what you will spend trying to get the little bits and bobs done, it's well worth paying the extra and buying a decent example with a good service history. Good luck with your search and hope you find what you are looking for. ![]() |
