Home > General > New member question on miles to tank TDV6 |
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 |
Hi Stewart, welcome
Mon May 06 2013 8:39pm |
stewart10001 Member Since: 06 May 2013 Location: Aberdeen Posts: 5 |
StuRRS,
Mon May 06 2013 8:45pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
Mine costs around 120 to fill I think and I get 390 to 420 miles normally Java black 2006 |
Mon May 06 2013 8:57pm |
Cheers, sounds like it will be a little better on the miles. the GV takes £70 to fill & lasts 300 miles max. the main reason im changing is due to needing something better for towing the horsebox. the grand vitara returns 9mpg with the horses. its just not got the power. perfect offroad though. |
Mon May 06 2013 9:02pm |
No Botha , 9mpg isnt a lot is it! think these will be much better for pulling your box Stewart Java black 2006 |
Tue May 07 2013 6:09am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8985 |
What's the GV's towing capacity? I'd be amazed if it was remotely legal towing a horsebox with two horses in it. The RRS, like the Disco and FFRR, is an excellent towing machine. Our horse box has a MGW of 2.5tonnes and the RRS pulls it without issue. I assume the 2.7 would find steep hills a bit more challenging but then that's one reason for having the low range box - they're almost unstoppable in low range! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue May 07 2013 7:41am |
Grand vitara has a 1850kg towing limit.
Tue May 07 2013 10:06am |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 |
I am currently getting 550 to 600 miles on a tank traveling between Essex and Warwickshire mostly m way at raming speed |
Tue May 07 2013 12:08pm |
Gary, which RRS do you have? i was happy at the 420 miles per tank but if you are getting 550-600 even better. |
Tue May 07 2013 12:22pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Drove Malin Head to London less than a tank of fuel - 520 miles |
Tue May 07 2013 2:36pm |
2.7 TDV6, but bear in mind I'm sat on the M way 90% of my trips, it equates to just over 30 MPG but during the winter I was down to around 27MPG. I had a week off a few weeks ago and just pottering about was down to 25? |
Tue May 07 2013 2:58pm |
