Home > General > Suspension knock
cocoapops123
United Kingdom 2007 Range Rover Sport TDV8 HSE Luxury Java Black
Suspension knock
I have a rattle/knock from the front suspension on rough ground at low speed approx. 10mph Sad Sad
Post #382242 Sun May 05 2013 8:49pm
The forum has a really good search facility. It's found by clicking on the "search" link at the top of the page. There's a whole sticky thread on suspension knock Wink
You'll probably find that either your anti roll bar bushes (ARB bushes) or your lower front control arm (wishbone) bushes are shot and in need of replacement. The ARB bushes are cheapest so try those first. There are other causes of noise but these seem to be the most common. 2012 SDV6 - it's missing a couple of cylinders
Post #382247 Sun May 05 2013 9:47pm
Disco_Mikey
Seeing as you have a TDV8, they all came with ARC, and the bushes are made from cheese...
Around 60-70k miles though, the front arm bushes may be getting a bit tired.
Post #382255 Mon May 06 2013 6:11am
Agreed. My ARB bushes were replaced at about 50k miles and the lower wishbones recently at about 63k miles. Rear ARB bushes were done when the rear ARB was replaced at about 50k miles. 2012 SDV6 - it's missing a couple of cylinders
Post #382259 Mon May 06 2013 8:02am
simple1
Mine just had an MOT. Yeah Rolling with laughter
Rear n/s and O/s track control arms had minimal movement in the ball joints according to advisory. Bit confused dot com as the tyres are wearing dead flat and from what I can see, the track control arms have bushes both ends and no ball joints. Might need to clarify that with Lexus dealer when I next go over as dealer uses them for Mot's. Shocked 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382276 Mon May 06 2013 12:30pm
Disco_Mikey
The ball joints are on the inner ends, attached to the chassis Thumbs Up
Post #382280 Mon May 06 2013 2:13pm
