Home > Technical > Preheater Started Working Again |
Corns-88 Member Since: 20 Feb 2013 Location: cheshire Posts: 26 |
Being a fairly new TDV8 owner ( Nov 2012), it took a while to realise that the pre heater wasn't working. So after searching in this forum, I read up all about how to reset it but had decided that i would get all the parts I needed later on, make up the lead and reset it in time for winter. However, 05:30 yesterday morning as my wife reversed of the drive it was working , tell tale smoke screen. How the hell has this happened. She even noticed the difference in heater temp on her way to work. Now I know that last winter the car was stop start halve a dozen times at least on one day before going to the petrol station with the diesel light on so it must have been locked out. I had it serviced last month would they have reset it as par for course or not. any ideas would be gratefully appretiated. 07 tdv8 stornoway grey at home tucked up
Fri May 03 2013 11:58am |
low fuel light will disable the FBH and the temp hs to be lower than 5 degrees also.
Fri May 03 2013 1:14pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
The heater is automatic, no switches there..
Fri May 03 2013 10:43pm |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 |
I mean the interior heater in the car, not the FBH
Sat May 04 2013 7:07am |
