![]() | Home > General (L494) > Engine sizes |
Can live with 6800 quid, from memory, the TDV8 was £53000 for base model, which was £15000 more than an HSE 2.7 |
It will be at least 6800 on top of the extra 8-10k you will need meaning you will be spending at least 15k for around the same spec anyway.
cmcb Member Since: 16 Jan 2013 Location: Edinburgh Posts: 33 ![]() ![]() ![]() |
Just give the car a good run in sport mode now and then with the revs above 2k and you shouldn't have any DPF issues. If when you are accelerating and making big black clouds then you can see the crud getting burned off!! |
