![]() | Home > Wheels & Tyres > Problems with center caps on my Kahn wheels. |
I bought 2010 Range Rover centre caps for my Khan wheels and they fit perfectly. Fleebay item number www.ebay.co.uk/itm/321095251100 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
I have the same center caps on my shelf and they dont fit. The clips are to small, but the all cap is fine. The hole on the wheels is to big :/
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
found my clips had gone weak, the caps fitted but were never going to stay put...
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Are they genuine centre caps and genuine Kahn wheels? Like this site? Buy some RRSPORT goodies to show your support! |
Well, the Kahn wheels are marked pretty well on the inside so I would say they are genuin.
So it is ok, to use a hot gun glue? Isnt there no problem getting them off later? 91 BMW 850CSI |
Hot glues like a wax, it peels off under pressure |
Then we have a solution.
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
awesome, I just got a pair of these for £300 that were refurbed by my friend, they just need new caps. So What did you do in the end? I'd like to get the right size of cap for these. |
