Home > Maintenance & Modifications > Problem with spare wheel winch. |
There are a couple of posts on here, one recently about how to repair the winch, might be worth a search. If your winch is tight you might be ok but I would want to be sure it's locked properly.
Sun Apr 28 2013 9:56pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Thanks mse, any solution or thoughts anyone else ? |
Tue Apr 30 2013 10:30pm |
JB, I think you might find this thread more helpful: http://www.rrsport.co.uk/forum/topic30676.html?highlight=winch If the cable is wound back on to the winch drum whilst there is no tension in the cable then it is likely to jam owing to overlapping turns. Those of us who sail keelboats are very familiar with this phenomenon and call it a 'riding turn'. I've not had the problem on my spare wheel winch but understand the first thing to try is remove the winch from the car (it's only four bolts) - secure it in a vice on a bench and then get someone to pull as hard as they can on the cable whilst you turn the winch operating bolt anticlockwise. If this doesn't work then try the dismantling procedure in the link. To avoid future similar problems - never wind the winch up without any tension in the cable. 2008 MY Java Black TDV8 HSE |
Wed May 01 2013 9:28am |
Many thanks Paddi, that's exactly the answer I was looking for.. |
Wed May 01 2013 2:39pm |
Wasnt that what i said basically Mike 2014 Facelift Discovery |
Wed May 01 2013 3:45pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
I had this problem, bought a secondhand one from Landrover Breaker.It did not work properly,sent it back and bought a new one.I took the old one apart to see how it worked and found the problem,. I had unwound the cable too far to get the wheel from under the car. And it had come to the end of the cable ,and started to wind the other way .It kinked the cable at the anchor end and jammed the whole thing up. I tried to straighten the cable but it would not go into the groove again.Solution Dont wind up without tension on cable, and dont unwind to far when taking spare off itisme |
Fri May 17 2013 8:43am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
^^^ Seems a particularly shoddy way to do things for a 50-80k car IMHO.
Fri May 17 2013 8:59am |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 500 |
Fri May 17 2013 9:24am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Lots of posts on Disco
Fri May 17 2013 9:40am |
No the spare is inside and has a internal winch type strap thing to get it out of the boot. Oh unless you go for seven seats then you dont get a spare. Mike 2014 Facelift Discovery |
Fri May 17 2013 2:33pm |
Cheers Mike ON THE WAY: BMW F21 M140i
Fri May 17 2013 2:37pm |
Here to help (or hinder ) Mike
Fri May 17 2013 2:56pm |
cristalfb Member Since: 09 Nov 2012 Location: Caloundra West, Queensland Posts: 3 |
Disco 3/4 RR Sport wheel winch repair.
Fri Jul 12 2013 2:06am |
BioBMS Member Since: 14 May 2013 Location: Oulton. Staffs Posts: 16 |
Pm for you cristalfb |
Fri Jul 12 2013 5:20am |
