Home > General > does the rrs sc have an overdrive.
shepp
Recently playing about and i have noticed especially when cold i can go all the way from 1st to 6th on command shift, noticing a rev change with every gear. Yet at 50mph i am at 2000 rpm, put it back to auto and it will upshift again to 70mph at 2000rpm. Anyone noticed the same as the rrs sc is meant to be 6 gears. But i can physically see and feel it change using 7gears.
Post #381597 Sat Apr 27 2013 12:19pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
No replies yey, so I'll start to get it going Very Happy
To be honest, I do not understand the problem exactly...At 50mph you put it back into auto mode and it will upshift agin to 70mph? Vadim A.
Post #381605 Sat Apr 27 2013 4:40pm
Whizzee111s
England 2010 Range Rover Sport Supercharged Santorini Black
What my s/c has gears never noticed lol lines 'stuck' 😜😜😜😜😇😇😇in sports mode and I never notice any gear changes as I'm to busy laughing and smiling hehehehehehe Freelander SE - Gone
S1 Elise - weekender
Rrsport S/C Autobiography 10 plate -well and truely here, but now stolen
Post #381606 Sat Apr 27 2013 6:34pm
mse
I'm sure it hasn't got one
; Mike
2014 Facelift Discovery
Post #381608 Sat Apr 27 2013 7:12pm
PEACHY
Whizzee111s wrote:
What my s/c has gears never noticed lol mines 'stuck' 😜😜😜😜😇😇😇in sports mode and I never notice any gear changes as I'm to busy laughing and smiling hehehehehehe
Strange that & mine Bow down Thumbs Up 16MY Estoril Blue SVR.............
Post #381611 Sat Apr 27 2013 7:18pm
Whizzee111s
Well it must have atleast two....... Very fast going forward and the other is a reverse one Freelander SE - Gone
Post #381612 Sat Apr 27 2013 7:46pm
Whizzee111s
I knew I wasn't the only one lol Thumbs Up Freelander SE - Gone
Post #381613 Sat Apr 27 2013 7:48pm
Shepp, i think you will find when you are putting it back into auto its actually dropping down a gear to 5th as you accelerate upto 70 mph it will automatically go up a gear to 6th. If your doing 2000 rpm's @ 50 mph then it will drop down a gear as soon as you press the accelerator, thats how the auto box works. Wink
Post #381614 Sat Apr 27 2013 8:37pm
Bobby
We went through this subject in the early days...anyway, hope this explanation on the driving modes helps...
Quote:
Normal Mode
Normal mode is automatically selected by the TCM on power up. In this mode all automatic and adaptive modes are active. Normal mode uses gear shift and lock-up maps to allow for vehicle operation which offers fuel consumption and emissions or driveability depending on the driving style. If the transmission is operated in sport or manual mode and the selector lever is moved to the 'D' position, normal mode is automatically resumed.
Sport Mode
Sport mode operates in high range only and provides enhanced acceleration and responsiveness. In sport mode the TCM uses shift maps which allow the transmission to downshift more readily, hold gears for longer at higher engine speeds, and limits the transmission to the first five gears (6th gear is not used).
Sport mode is selected by moving the selector lever to the left into the 'M/S' position. When the sport mode is first selected, 'SPORT' is displayed in the message centre for 6 seconds and, if 6th gear is currently engaged, the TCM downshifts to 5th.
Manual (CommandShift) Mode
Manual mode allows the transmission to operate as a semi-automatic 'CommandShift™' unit. The driver can change up and down the six forward gears with the freedom of a manual transmission.
Shift maps are provided for manual mode to protect the engine at high engine speeds. The TCM will automatically change up to a higher gear ratio to prevent engine overspeed and change down to a lower gear ratio to avoid engine labouring and stalling.
When kickdown is requested the TCM downshifts at least 2 gears.
When the vehicle is stationary, to drive off the driver can select 1st , 2nd or 3rd gear in low and high range. Any other gear selection will be rejected by the TCM.
When driving off, upshifts can be pre-selected by making + selections with the selector lever for the number of upshifts required. The TCM then automatically performs a corresponding number of upshifts when the appropriate shift points are reached. So, for example, when starting off in 1st gear, if three + selections are made in quick succession, the TCM will automatically change up through the box to 4th gear as the vehicle accelerates, without any further selections being made.
In manual mode a low gear can be selected to provide engine braking for descending a slope without HDC or continuous use of the brake pedal. The driver can prepare for the end of the descent by moving the selector lever to D. The TCM will maintain the low gear and only revert to automatic shift control when the throttle is opened and vehicle speed increases.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #381638 Sun Apr 28 2013 9:00am
shepp
Hello all
Thanks for the replies. Firstly I do not have an issue, I live 5 minutes from a quiet bypass and when joining from a roundabout, I select 1st and go through all the gears noticing the rev change, In command shift I get up to 6th gear at 50mph at 2000 rpm (which is high revving for 50) then if I change back to auto, it will change gear again to be doing 70mph at 2000rpm.
just seems odd to feel the extra change, I would expect 6th gear to be at 2000rpm in command shift.
I have only ever tried this when cold and driving steady.
Post #381646 Sun Apr 28 2013 12:05pm
simple1
Often wondered if there were seven in my tdv6 box. I do know that when towing that I can't get 6th unless I select it in command shift. When I asked tech about this he told me the canbus detects trailer plugged in and tells gearbox to start in 1st and not to select 6th. Just have to remember to select 6th on motorway when towing or mpg goes out the sunroof Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #381647 Sun Apr 28 2013 12:27pm
Disco_Mikey
It sounds like the torque convertor is not locking up until the engine coolant is up to temperature Whistle
In 6th gear when cold, the revs will be slightly higher than 2000rpm, then once the coolant hits a certain temperature, the TC locks up, for better fuel economy...
Perfectly normal, and only 6 gears, plus reverse
Post #381653 Sun Apr 28 2013 2:37pm
shepp
Cheers disco mikey. That makes sense, is never been an issue. just seeing if any one had an explanation. As i know it only has 6 gears but feels like 7 when cold.
Post #381659 Sun Apr 28 2013 5:06pm
