Home > Faults & Fixes > The "Faults & Fixes" forum
Martin
Site Administrator & Owner
Hi all,
This new section is intended for the sharing of faults along with their fixes.
If you know of a Range Rover Sport issue which has a known fix, please share it here so we can build up an archive of fixes and solutions.
DO NOT ask for technical help for a problem here, this should be posted under General or Technical instead.
Any suggestions for the use of the new forum to improve it are warmly encouraged Thumbs Up Like this site? Buy some RRSPORT goodies to show your support!
Post #316349 Thu Oct 06 2011 11:03am
Martin
Since the Discovery 3/4 and Range Rover Sport share so much of their architecture and engineering it is also worth checking the following links:
Post #316352 Thu Oct 06 2011 11:09am
Martinberry1
2005 Range Rover Sport TDV6 HSE Bonatti Grey
RRS problem
I have a thud that goes right through the car at low speed up to about 40 the dealer has looked at it five times and can't find anything wrong they said they took it to range rover and plugged it in but there's no fault in the box this thud is bad has anyone had this problem and no what it is they changed the gear box mountain but its still there help
Post #381448 Thu Apr 25 2013 3:30pm
Disco_Mikey
A little more information would be helpful, such as what age the car is, how many miles, what engine, does it do it all the time etc...
Also, asking the question in the correct part of the forum will result in many more people seeing the question, and may have an answer for you
Post #381480 Fri Apr 26 2013 5:52am
Martinberry1
Hi Micky sorry first time using this site the engine is 2.7tdv6 on a 55plate and has done 76500 and yes it dose it all the time if I'm rolling at low speed and push the throttle quickly 9 out of ten times it dose it can you help thanks martin
Post #381524 Fri Apr 26 2013 12:58pm
MR08ASH
United Kingdom 2008 Range Rover Sport TDV8 HSE Sumatra Black
Hi guys it my first time on here. I also own one of these monsters. V8 3.6 2008. i will be posted pics so u can view. I wants to know where is the lower air con port so i can fill it up. Thanks guys waiting for reply. Hope to have a good communication with u all.
Post #496364 Tue May 17 2016 9:19pm
Plazmapete
Take it to a Garage
Post #498558 Mon Jun 13 2016 12:20pm
Plazmapete
Take it to Halfords or kwikfit. Mine was completely empty. £49. Good price.
Post #498560 Mon Jun 13 2016 12:22pm
Cheryltyla
RRS NOT LOCK OR UNLOCK WITH FOB!!
Hi.. My RRS 55plate 4.2 v8 supercharged is being a bit temperamental at the moment, I've had it just over a year and had no problems.. Been away for the weekend and whilst away it wouldn't lock or unlock, I was having to unlock/lock using the passenger door handle.. Got back to home town and was ok for a few times... This morning it's at it again.. Any ideas?? .. Thanks
Post #499619 Mon Jun 27 2016 12:22pm
Johnski
You shouldn't attempt to refill or charge Air Con systems, there are strict rules and laws on this, due I believe to release of hazardous gasses into atmosphere. This applied more to the old gas used in air con systems. People carrying this out have the proper equipment to drain and capture and refill your system, and add a dye if a leak is expected. If you have this equipment then I apologise. I believe (told read somewhere) you can purchase tins for DIY, but not ad visible as you can get severe burns and wouldn't wish injury to any members.
There are many specialists out there that can do it, or the multinationals using a all in one self contained unit. John
Post #499621 Mon Jun 27 2016 12:30pm
Paddi
Remember finding the ports once - think they are next to the battery on the inboard side; you'll have to take off the battery dust cover to see them. 2008 MY Java Black TDV8 HSE
Post #499625 Mon Jun 27 2016 1:46pm
