Home > General > Someone please help me !!!!!! Please read !!!!!
Ross_wida
2006 Range Rover Sport TDV6 HSE Siberian Silver
Hi everyone I hope someone can help yesterday my 2006 range rover sport developed a fault which was hdc fault and after investergation I found out that is was the rear right wheel speed sensor so I changed the sensor and still had the same problem so I took my wheel off again to looked at the sensor to find out that the wire I plugged my new sensor in has a break in the wire just before the plug there is two wires one is white and the other is white with a green stripe is the white one that has broken but I cannot see any cooper core or anything ? I have been told today that I may have to replace the whole wiring loom on the car as this wire is cam bar fibreoptic ???? It looks like a normal wire but can't see any core !?? Can some one please help me can I get this wire repaired ? Or has anyone else had this problem ?
Post #381058 Sat Apr 20 2013 8:44pm
The system is CANbus i.e. it's a network rather than a traditional loom (if that makes sense). I'm not aware of any fibreoptic being used. 2012 SDV6 - it's missing a couple of cylinders
Post #381060 Sat Apr 20 2013 9:17pm
Ross_wida
So would that mean I can just rejoin the wire ??? Or because its can bus is that not a normal wire ??? Many thanks for your reply mate
Post #381061 Sat Apr 20 2013 9:19pm
Disco_Mikey
If the wire is broken, just rejoin it Thumbs Up
Fiber Optics are only used on the MOST system
Even the CAN BUS network uses normal copper wire Thumbs Up
Post #381062 Sat Apr 20 2013 9:30pm
mse
As said - remake the wire, simple
You might not see the core depending on how it broke
There will be fibres on the car - but the majority (most sensors) are good old normal wire. Mike
2014 Facelift Discovery
Post #381068 Sat Apr 20 2013 9:43pm
