Home > Tips & Tricks > speed cameras can now be downloaded onto the Sat Nav
Page 3 of 4 <1234>
jimbg
Did you chose this?
Select The Database You Require
To Download the Same Again:
You last downloaded...
Other - GPX [ UK - Consolidated by type (Gatso,Mobile,etc) | pMobiles: Yes | French: No | Swiss: No ]
(11.034 - 27 Mar 13)
There should be 5 pairs of camera files. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #380792 Thu Apr 18 2013 7:42am
AndyBrew
United Kingdom 2013 Range Rover Sport SDV6 HSE Luxury Fuji White
No I just noticed that there were two I downloaded the Other UK file, I will try the one you have shown there now, and report back.
Post #380794 Thu Apr 18 2013 7:47am
AndyBrew
Works perfectly with the other file, what a dingbat I am, never ceases to amaze me how with two options I always pick the wrong one, don't think I'd have been a very successful bomb disposal expert Rolling with laughter
Thank you very much, all good now Bow down
Post #380795 Thu Apr 18 2013 7:56am
jimbg
Well Done, you got there in the end!! Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #380799 Thu Apr 18 2013 8:34am
AndyBrew
ok everything is working as expected however, for a mobile camera site you need to be notified a little earlier because by the time it has told you you have already been zapped??
I guess this is something the Sat Nav controls and we have no say in it?
Post #380825 Thu Apr 18 2013 3:28pm
jimbg
The problem is that it is only a point of interest and the system sounds the alarm when you enter a "proximity circle" around it.
Not sure how big that circle is, and course the other problem is that is does not understand direction only your proximity to the POI.
So, it will sound an alarm even if you are coming in the opposite direction. Does that make sense? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #380832 Thu Apr 18 2013 4:58pm
AndyBrew
Yes I understand that, you just need a bit more notice for speed cameras so you have chance to address your speed before they/it sees you, but as you say it's not designed for that purpose Crying or Very sad
I wasn't sure whether the proximity would be controlled via the GPX file and thus a bit of tweaking and we could have increased the radius for these POI's.
I guess the easiest thing to do is not break the speed limit Whistle
Regards,
Andy
Post #380834 Thu Apr 18 2013 5:08pm
jimbg
I have not really used them yet in the RRS, in the previous car it seemed to be linked to your speed.
So the actual time in advance for the alarm to sound was the same regardless of travelling at a crawl or high speed.
I have always assumed that it was the software not the GPX data that controlled this.
Jim 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #380845 Thu Apr 18 2013 5:42pm
craig782
Re: speed cameras can now be downloaded onto the Sat Nav
pko wrote:
At last, Land Rover have listened. On my 2013 RR/sport black it is now possible to import your own POIs onto the in car sat. nav. In my case I have imported the gpx speed camera files from pocketgpsworld via usb onto the car satnav including audible warnings & symbols.
I haven't taken it on a test run yet as I live a few miles from my nearest camera, but they are all showing on the map.
Also, I've just read that the headlamps no longer need to be adjusted for foreign travel.
It pays to read the handbook now & again.
regards to all
P
Thanks for posting this...
It was a thing that niggled me and kept meaning to look into but you've saved me the trouble
All done and working
thanks again
Post #381396 Wed Apr 24 2013 8:32pm
dvb247
England 2012 Range Rover Sport 3.0 TDV6 HSE Alaska White
I'm not having any luck with downloading the files, I have registered on the pocketgpsworld and there is a set of blue tab across the webpage, one tab says Free Downloads, from there I'm lost as I can't find Other GPX, can someone email me the files or are they really large?
Thank you Bow down If you've got it, spend it!
Post #382212 Sun May 05 2013 9:09am
craig782
Log in with your user ID
Hover over the the "Speed Cameras (download now)" blue tab and click "Download Speed Cams")
This will open a new screen
Scroll down to the Sat Nav system selection
Now you should be able to select "Other GPX"
Ta Daaa Thumbs Up
Post #382271 Mon May 06 2013 11:17am
dvb247
Login and I get a blue tab that says Speed Cameras (subscribe now) still can't find other gpx Big Cry If you've got it, spend it!
Post #382290 Mon May 06 2013 3:38pm
jimbg
Are you on this page?
http://www.pocketgpsworld.com/modules.php?...er=SideBar
The database is 7 from the bottom just before "polstar"
You have paid the subscription? Shocked 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #382291 Mon May 06 2013 3:48pm
dvb247
was hoping not to Rolling with laughter oh well Whistle If you've got it, spend it!
Post #382292 Mon May 06 2013 4:10pm
jimbg
"If you've got it, spend it!" Mr. Green Rolling with laughter 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #382298 Mon May 06 2013 7:29pm
Page 3 of 4 <1234>
