![]() | Home > General (L494) > Dynamic Response on which model ? |
If you have Terrain Response 2 Auto it will have Dynamic mode...it will be there - the configurator isnt that good...just download the catalogue Mike
DBA Member Since: 20 Mar 2013 Location: Skopje Posts: 51 ![]() ![]() |
I think he meant Dynamic Response Program, which uses the air suspension to help reduce roll. TR Dynamic mode i guess is used to stiffen suspension and steering to sharpen the drive on demand as on the Evoque. It would be more usefull, if LR had more infornation on these technologies and provude some concepts if they work. Maybe some instructionall videos... |
I know, which is part of the terrain response system (as is the same on the current cars ![]() 2014 Facelift Discovery |
Laurent T Member Since: 04 Apr 2013 Location: Paris Posts: 2 ![]() ![]() |
Thank you for those feedbacks. Indeed the catalogue is showing some options and details you cannot find in the configurator. Dynamic verisons include as standard the active body roll control and if you spec an HSE with the SDV6, you can get as option the On / Off Road Pack which includes twin speed transfer box, Terrain Response® 2 Auto (including Dynamic program), Dynamic
The UK usually gets more and better specs, for a number of reasons. I cant say the specs of the new RRS impresses though Mike
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Nope! Rubbish spec's for such an expensive vehicle!
I think you missed my point in the above post or my general points.
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 ![]() ![]() |
What are these "hotfire" engines and why do you think they'll impact resale of the early 2013 RRSs? Are they significantly better (more powerful/economical)? |
Hotfire engines will be specifically built for the 'new' LR range and will be placed in all their models from 2014. LR are building a new engine plant that will only manufacture these engines.
I doubt that to be honest - yes JLR are building a new plant in Wolverhampton to make its own engines, but this isnt a new concept and to say values of the current will tumble because of that is a little extreme Mike
If given the choice which model would you buy - the new up engined one with a 9 speed box or the old 8 speed SDV6?
Thats not true either...the UK is still one of the most significant markets
You are not an ex Crab Officer are you MSE?
i would comment if i had any idea what you meant Mike
