![]() | Home > General > Gas struts for tailgate |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Crikey, you shouldn't have to be accepting 'send them back to us and we'll top them up a bit', get a full refund and buy the genuine parts for christs sake. Cowboy outfit by the sound of it..... |
wilburn Member Since: 09 Aug 2010 Location: Shropshire Posts: 82 ![]() ![]() ![]() |
The issue is I gave the spec for the left hand one so was sent two to that spec. It turns out the right hand side one should be more powerful so all should be fine if the right hand side one is more powerful. The reason I didn't opt for genuine landrover ones is after 2 years they were rusting already so thought I'd try alternatives. |
Rust? Mine have been on four years and not a spot of rust anywhere on them. To rust the chrome or paint finished gas been damaged. And to damage the chrome you need to bend the things. 2x TDV6. SE and HSE. Both returned to sender with issues👀
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 247 ![]() ![]() ![]() |
Just looking to replace mine, Going off this trhread it seems alot get 2 struts with the lower pressure instead of the rh which has more Nm. So would relplacibg both with 2 struts the same but the RH would this be ok?
https://www.rrsport.co.uk/forum/topic57437.html
Only issue with them Kilen ones is they’re advertising the same strut for both sides so they can't be to spec which is what i would prefer if Land Rover state RH needs to be stronger.
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 ![]() ![]() ![]() |
Powerful do a replacement for the original ones that are symmetrical but at the right total force. Very reasonable. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
https://www.powerfuluk.com/tailgate-gas-st...nuine.html Gone: 10MY L320 RR Sport HSE, Ipanema Sand
