![]() | Home > Technical > Lazy air suspension on o/s front ? |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
Have had an issue from purchase on the air suspension, quite often goes into extended mode when switched to access mode. Also noticed the o/s front doesnt always go down or if it does is the last one to do so... Regardless of surface and angle tile this is switched to.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
It could be a height sensor beginning to play up. Ideally, you need to watch the live readings as you lower the car.
I understand fully.. But the problem was there before the lowering |
As said, the car thinks there is an issue. You need to watch all 4 corner heights as the car lowers to see which one stops moving |
So am i assuming the corner thats not moving is going to be a sensor not reading correctly a faulty valve and or strut ? Why?.. Because i can....
usually its a height sensor, but i have seen one where it was a shock absorber that wasn't moving very quickly. Look at your 4x4 info screen, might help identify and put the ride height adjusters back to std just to make sure its not confusing it at the extremes.
