Home > General > humming from front end
2 weeks ago I had a squeeky brake.
Yesterday while picking up the new caravan I noticed a new sound, a quiet hum from the front.
It didn't vary with left or right turns so I didn't think it was bearing related, so had a look at the front calipers/discs this morning.
The NSR disc has two quite deep (0.5mm) grooves around 2cm apart. (Not there the last time I washed it)
I'm asuming 2 stones have lodged into the pad and are now bedded in causing the rubbing noise?
Is the disc written off of would I get away with just pads. RRS gone
Post #378638 Wed Mar 27 2013 8:56am
simple1
For 100% efficiency you should really replace the discs. Motor factor quality is perfectly good enough for rears. Would be a bit more concerned about noise from front. Mine did this about same time last year while towing new van and though lighter than last one, I put it down to this. It turned out to be front diff failure so get it checked out. It is becoming a known issue and when mine was being sorted, there were under breathe comments about the wrong oil being put in it the previous year when a seal and breather were replaced. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378640 Wed Mar 27 2013 9:07am
I wouldn't worry too much about the grooves awd, just look at the performance disc on sports cars, they come grooved and drilled Thumbs Up It might help with the cooling on your rear brakes. Wink I'd check that it hasn't destroyed your pads though.
Post #378643 Wed Mar 27 2013 9:25am
Humming from the front you say.............. Idea .......maybe it doesn't know the words............ Whistle Laughing
Don't worry, I'm getting my coat Embarassed Mr. Green ON THE WAY: BMW F21 M140i
Post #378645 Wed Mar 27 2013 9:26am
Bradders
I'd go along with a bearing for a humming noise. Jack up the wheel and give it a good wiggle Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #378651 Wed Mar 27 2013 9:36am
simple1
Another pearl from Mr Counter....... Made me chuckle Bow down Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378652 Wed Mar 27 2013 9:37am
I thank you. Embarassed Mr. Green
I'm available for parties, weddings and bar mitzvah's Whistle ON THE WAY: BMW F21 M140i
Post #378653 Wed Mar 27 2013 9:40am
Just got back from my little independant and it's bearings Big Cry
NSF is wobbley and OSF is rumbling.
Any mobile guys on here want a trip to sunny Wiltshire to replace them?
I'm on holiday with the caravan Wednesday next week and currently none of my local garages can accomodate me before then Big Cry . RRS gone
Post #378655 Wed Mar 27 2013 9:41am
simple1
You have to agree to be supported by the Wurrzles down ere Rolling with laughter not too sure there are too many bar mitzvah bookings to be had,more into summer and winter solstices Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378660 Wed Mar 27 2013 9:56am
Bradders
awd man wrote:
Just got back from my little independant and it's bearings Big Cry .
Yay me.....Im still waitin to hear what's up with mine. Big Cry Big Cry Big Cry FF 4.4 V8 Soooo looking forward to this bad boy
Post #378706 Wed Mar 27 2013 1:25pm
