![]() | Home > Technical > struggling to start |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Sounds like glow plugs but hopefully someone with more experience can confirm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Glow plugs |
Danny Byrne Member Since: 26 Feb 2012 Location: Dunfermline Posts: 127 ![]() ![]() ![]() |
I asked my independent about this yesterday? It's in on the 17th of April to get the belts done anyway! Thing is I left it at the airport for two weeks and it turned over straight away on my return? It's just struggled the last 2 mornings! His initial response was glow plugs, so we'll see what happens, as usual it will get what it needs!! How much are you looking at for a set of glow plugs fitted?? it's starting to look expensive with belts etc??? |
Glow plugs are £60 or so + VAT, plus a couple of hours labour, if they come out.
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 ![]() ![]() ![]() |
Would leaving it turned on for a few seconds before starting help like on older diesel vans |
Try letting it go through its glow plug cycle twice before starting. Ie after glow plug light on dash goes out, switch ignition off then switch it back on, when glow plug light goes out again, try starting, it might start up quicker that way. |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Thanks for all the replies. Sorry for not replying earlier. Defo glow plugs I think, im not even going to attempt to remove them after all the reading i have done on the likelyness of them snapping.
